How could I get the gradient values at the edge tools
I can't get the gradient values information from the edge detectors.when i use this function, the gradient values are returned as 0.
(2,938 Views)
  • We can't do much with pictures of code.  Attach the actual code (hint -- it's a file whose extension is .vi).
  • Express VIs (such as the Vision Assistant) are fine for simple things, particularly if you have a good understanding of what you are doing.  To do anything complex, you should learn how to work with the IMAQ functions directly.
  • Is there a particular Image you are studying?  Along with the code, it doesn't hurt to attach some data.
(2,904 Views)
i just wanna get the strength profile(or gradient value) of the selected line
(2,893 Views)
