How come my local variable is not updating it's value with respect to what's happening in the while loop?
I am trying to extract data out of a while loop as my declarations update with respect to the iteration number. I have attempted to use both local variables and shift registers, but with no luck.
I have also done the following example: http://www.ni.com/white-paper/7585/en and it works like a charm.
I attached the PNG file with local variable declaration circled in red. Will attach a VI in the next respnose.
Message 1 of 10
(6,851 Views)
That's not a local variable, but a value property. It gets read exactly once at the beginning of each iteration of the outer loop, each time before the code in the inner loop ever writes to it.
Sorry, posting by phone. I'll look at the code later.
Message 3 of 10
(6,834 Views)
OK, looking at the code...
Can you explain what it is supposed to do? What's the purpose of the value property node read which only seems to update an indicator.
The inner while loop should proably be a FOR loop, because the number of iterations is known before the loop starts.
Your use of formula nodes seems overly complicated.
Message 4 of 10
(6,816 Views)
The examples in this application note do not resemble anything in your code. Where is the connection?
Message 5 of 10
(6,809 Views)
Basically, I want to get the iteration value out of a while loop. The counter will keep incrementing, but the indicator will only update once the loop is finished, not during the loop.
Message 6 of 10
(6,788 Views)
Then you need to read it in a second loop that runs in parallel.
(run your code in highlight execution mode while watching the diagram to get a better understanding what your code is doing)
Message 7 of 10
(6,786 Views)
To my nowledge it is being run in a parallel while loop. One while loop inside the false case statement, and the local variable being written in the while loop running the whole program.
Message 8 of 10
(6,780 Views)
Accepted by topic author TacomV
No, the two while loops are stacked and not parallel, meaning the outer loop cannot go to the next iteration until all code in it, including the inner while loop has completed.
Message 9 of 10
(6,772 Views)
Ah that makes sense. Thank you very much.
Message 10 of 10
(6,769 Views)
