How can you make a connection DAQCard-A1-16E-4 and Labwindows?
I have problems in my research. I would like to have a connection between the DAQCard-A1-16E-4 and Labwindows in order to manipulate some variables. I don´t have any idea to do this. Can someone please help me?Smiley Indifferent
(3,082 Views)
The first thing you should do is look at the shipping DAQ examples. The second thing to di is to post your LabWindows question in the correct forum. This is the LabVIEW forum.
(3,082 Views)
Your DAQCard-AI16E-4 has driver support in Traditional DAQ.  The newest version of the driver available can be found here:
http://www.ni.com/support/daq/versions_portable.htm#pcmcia
In order to be able to program in CVI, you must have installed support for CVI when you installed the Traditional DAQ driver.  If you did not install the CVI support, simply reinstall the driver and include the support.  Once you have installed Traditional DAQ CVI support you will have shipping examples available to you.  You can find the examples under the help menu (Help >> Find Examples then select Hardware Input and Output >> Traditional DAQ).  You can also find lots of examples on our webpage.  You can search the example program library (found here:  http://www.ni.com/devzone/dev_exchange/ex_search.htm)
You can find example there like the following on Analog input and start triggers (found here:
 http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EF8356A4E034080020E74861).
Make sure to look for Traditional DAQ examples and not DAQmx.
Finally, in CVI if you look in the libraries tree under ‘Traditional NI-DAQ Library’ you will find all the functions available to you.  To find out information on a specific function right click on that function and select ‘Function Help…’.
Jesse O.
Application Engineering
Jesse O. | National Instruments R&D
(3,067 Views)
Lightning can you please contact me in regards to DAQCard-A1-16E-4 I am looking to buy it.
(2,893 Views)
duplicate post. Don't spam the forums with the same question multiple times.
(2,884 Views)
