How can you insert delays between characters transmitted on COM1 to a routine generated with I/O Assistant? / LabWindows/CVI
The Sun TC01 temperature chamber I'm working with uses a 9600 Baud serial interface for control.  The example Basic code I've seen for the interface inserts delays between each byte sent to the temperature chamber.  I tried using the I/O Assistant (without the delays) and cannot get commands that consist of more than one character to work.  I'm concluding that a delay of 100 milliseconds or so is actually required between the characters.  So how can I customize the I/O Assistant generated code to fix this problem?
(2,675 Views)
You'd get a better answer if you posted to the LabWindows forum instea of LabVIEW.Smiley Very Happy
(2,671 Views)
Thanks, actually.  Missed which board I was on.
(2,667 Views)
