How can we call a C program in Labview
ah, but remember: you can't call a dll-function that requires user input on the terminal (printf etc..) from LV. you then have to do all user-IO with LV and let the dll only do the data processing.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 11 of 13
(689 Views)
iam having the doubt of how to creat a DLL file for a cprogram
urs
selva
Message 12 of 13
(642 Views)
thanks for ur imediate reply
my application is to call a C program from LabVIEW.
C prog. requires some input. those inputs iam going to give thru LabVIEW front panel. the c program should accept the input from the LabVIEW and process it and it shuld return the output put Which i want to disply in the indicator which in the front panel.
(say take simple addition program of two inputs A&B, let the output be D.i will give A&B from front panel and get the D also in front panel. but the processing of these data is going to be done by 'C' program which iam going to call thru call library function
urs
selva
Message 13 of 13
(641 Views)
