How can this be done? For Loop state Machine question! See attached code.
I created a for loop state machine. So I would like my state machine to start from Level 1, then on the "timer state" I want the timer to go up to 10 seconds before moving to the next level which is level 2, then level 3. Then repeat.
Right now, it keeps skipping the state timer without getting to 10 seconds.
Can someone help? I am also working on it myself.
Thank you!
(1,173 Views)
Highly flawed
  • You only need toe outer loop
  • Changing state should depend on the elapsed time. a LED does not change states.
(1,164 Views)
Hello Mr. Altenbach, Is this what you meant? Yes, I just noticed that led is not even turning on. I am working on it too. Maybe I should just stick with the traditional state machine taught in core 2 or 3.
(1,156 Views)
Accepted by topic author GRCK5000
Note that you don't want to have the wait depend on the loop rate, so use actual elapsed time as in this example that we already discussed long ago. remember?
(1,140 Views)
Thank you, Mr. Altenbach! Yeah, I remember this. This really helps.
(1,034 Views)
