How can read 3D Volume
Dear NI.
I have attached the LabVIEW program (Test_3D Volume Generation). It's generate the 3D_Volume and can save to 3D_Volume.txt
How can read the 3D_Volume.txt? I hope to someone help me the make the 3D_Volume read program.
Thank you.
(2,441 Views)
Hi DG2708o1 (whoa - that's a tough name to remember...),
With an advanced data structure like yours, I would suggest that you use Datalog files instead of simple binary files. Using a Datalog file, you can save multiple 3D arrays in the same file and easily retrieve them without any problems.
I have attached an image of what you will need to change your VI to write to a Datalog file instead of a simple binary file, and on the same image you can see what it takes to read the file. And yes; I tested it and it works like a charm!
Have fun!
Message Edited by Philip C. on 06-01-2005 12:14 AM
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,438 Views)
