How can i use Numeric to plot gragh ?
 How can i display the numeric output from the string to plot onto the gragh ? As for now, once i run the VI, there won't be any output shown on the graph.
Message 1 of 10
(4,229 Views)
Hi falcoz,
currently its only one point. You can see this point if you change the plotstyle.
Mike
Message 2 of 10
(4,220 Views)
Right click on the Reset input and select "Create Constant". If it creates a True constant, change it to false.
Since I don't see a while loop anywhere, you will only get a single point. Your point style is probably set to none so you would not see anything. Change that.
Message 3 of 10
(4,219 Views)
 Thanks alot. I have change the plotstyle and awhile loop. I can manually draw a graph now but if i would like to simulate a voltage and current value into graph, how can i do it ? By inserting array or ? If is insert array, where do i place it ?
Message 4 of 10
(4,204 Views)
You can just build array
Message 5 of 10
(4,152 Views)
thanks muks, but how can i combine the array with my VI as my input is a string and the output is actually separated out into voltage and current.
Message 6 of 10
(4,141 Views)
I am not getting it. Can you tell me what is your input and expected output?
Message 7 of 10
(4,135 Views)
As you can see from my attached VI in the earlier post, in the string box (eg. 4.23 V 4193uA ), it is actually separated into Voltage box and Current box.  My idea is how can i create a string array to simulate onto the voltage and current graph.
Message 8 of 10
(4,131 Views)
You mean to say you will be continously getting values like (4v3a5v2a etc)
Message 9 of 10
(4,117 Views)
Yes muks.
Message 10 of 10
(4,115 Views)
