How can i save to the excel file my scanned values which are shown in a chart?
How i can do that, so that i can see the y-values corresponding to the x-values in the excel file?
furthermore, i hope that i can save max. 50 separate scans to the file.
(2,778 Views)
Hello Jani,
The easiest way to accomplish this is to use the Write to Spreadsheet File VI. Attached is an example where I chart 3 plots and then take the data and turn it into an array that can be saved.
To save the data into an excel specific file you will need to use the NI LabVIEW Report Generation Toolkit for Microsoft Office
or program the ActiveX calls manually.
Good luck with development,
Matt F
(2,778 Views)
I dont know is it possible to first do the scan or data aquisition, and then there is button "save", so i need something like buffer?
I press button Aquisite, and then there is digital signal start and stop. After stop signal, i can see results. After that, i can save if i want.
i have 2 graphs and several time measurements.
But thanks for your answer, it shows the way to do movement to the excel.
(2,778 Views)
