How can i run the example programme without hardware?
Hi
     We are using NI-9233 for our Project. We would like to run the example programme, the NI-9233 getting started(host).vi ... I would like to ask that how can i run the Programme without Hardware.& How shall i get the input signal (simulating signal)?because we would like to test it while we are waiting for the hardware to be delivered .
thanks
(2,833 Views)
why do you start so many threads for one topic? continue here
(2,829 Views)
On May 20, 2:10 am, NI9233 <x...@no.email> wrote:
> Hi
> &nbsp;&nbsp;&nbsp;&nbsp; We are using NI-9233 for our Project. We would like to run the example programme, the NI-9233 getting started(host).vi ... I would like to ask that how can i run the Programme without Hardware.&amp; How shall i get the input signal (simulating signal)?because we would like to test it while we are waiting for the hardware to&nbsp;be delivered&nbsp;.&nbsp;
> thanks
> &nbsp;
> &nbsp;
Measurement and Automation Explorer has the capability to simulate
much of the data acquisition hardware National Instruments sells.
Unfortunately the NI 9233 is not include in the list of products it
can simulate. Hence it appears you will have to wait until your NI
9233 is delivered to start working with it.
Howard
(2,799 Views)
As I mentioned in the other thread which MikeS81 referred to, you can use an FPGA emulator to test code developed for a CompactRIO.
If you were using CompactDAQ, you could simulate a cDAQ-9172 chassis in Measurement & Automation Explorer and add the NI 9233 module to that system.
Jennifer R.
(2,781 Views)
