How can i run the example programme without hardware
     We are using NI-9233 for our Project. We would like to run the example programme, the NI-9233 getting started(host).vi ... I would like to ask that how can i run the Programme without Hardware.& How shall i get the input signal (simulating signal)?because we would like to test it while we are waiting for the hardware to be delivered .
thanks
Best regards
Message 1 of 9
(6,775 Views)
Hi NI9233,
you can simulate this device in the MAX (measurement and automation explorer). I don´t know the getting started vi. Can you please write the real name of it?
Mike
Message Edited by MikeS81 on 05-20-2008 08:48 AM
Message 2 of 9
(6,763 Views)
Hi ,
        i mean the example program for NI-9233 called NI-9233 getting started (host).viproj in NI Example Finder, located in Hardware Input and Output>>CompactRIO>>Module Specific>>Analog Input.
Sorry for duplicate messages ...
With Regards,
Su
Message 3 of 9
(6,750 Views)
As Mike indicated, you can use MAX to simulate some (not all) DAQmx devices. There's a NI-USB-9233 device that you can probably use. Open MAX, then expand "My System", the expand "Devices and Interfaces", then right-click on "NI-DAQmx Devices" and select "Create New NI-DAQmx Device -> NI-DAQmx Simulated Device". Select the device from the list. See the online help for MAX for further help.
If you don't see "NI-DAQmx Devices" in MAX you need to install NI-DAQmx. You can download it from NI here.
Message 4 of 9
(6,717 Views)
Hi Su,
It sounds like you are using the NI-9233 with a CompactRIO, not Compact DAQ.  If so, you may be interested in running your code on an FPGA target emulator.  This functionality is available if you have LabVIEW 8.0 or above.  Right-click the FPGA target, select Properties, and set the Emulator to On - Use Random Data for Inputs.  More information can be found here.
Jennifer R.
Message 5 of 9
(6,689 Views)
As Mike indicated , " you can use MAX to simulate some (not all) DAQmx devices. There's a NI-USB-9233 device that you can probably use. Open MAX, then expand "My System", the expand "Devices and Interfaces", then right-click on "NI-DAQmx Devices" and select "Create New NI-DAQmx Device -> NI-DAQmx Simulated Device". Select the device from the list. See the online help for MAX for further help.
If you don't see "NI-DAQmx Devices" in MAX you need to install NI-DAQmx. You can download it from NI here. "
hi,
     the link you gave me to download is "NI-DAQmx Devices" ... There is no software to download for Labview 8.2.1. So should i use 8.1 or 8.3 instead of 8.2.1 ? If not, can you tell me the CD no. that includes the "NI-DAQmx Devices" folder of Labview 8.2.1 version? Because we can get the cd from our school's component store. Thank you so much.
Best Regards,
Su
Message 6 of 9
(6,634 Views)
Hi NI9233,
the link shows the different versions of DAQmx, not which are available for LabView. You can use the lastest version of DAQmx, so download 8.7.1, if you don´t have it.
Hope it helps.
Mike
Message 7 of 9
(6,626 Views)
 I downloaded the NI-DAQ mx. Opened MAX, then expanded "My System", the expanded "Devices and Interfaces", then right-clicked on "NI-DAQmx Devices" and selected "Create New NI-DAQmx Device -> NI-DAQmx Simulated Device". Selected the device from the list....
What should i do after doing all these thing ? (i would like to have a simulation signal for my example program to run for testing )
Message 8 of 9
(6,582 Views)
Hi Su,
What chassis are you using with the 9233?
The project called NI 9233 Getting Started is for a CompactRIO system.  This requires LabVIEW FPGA and the NI-RIO driver.
If you are using CompactDAQ, with the NI cDAQ-9172 chassis, you can use a simulated DAQmx device and DAQmx examples.  Examples which can be run with a CompactDAQ system are under Hardware Input and Output » DAQmx.
Jennifer R.
Message 9 of 9
(6,563 Views)
