How can i receive "numbers" i.e. an integer using Visa Read ??
How can i receive "numbers" i.e. an integer using Visa Read .. i'm using visa write to send data from a numeric control to the micro-controller via serial interface by casting the "number" to "string" using Type Cast function .. now i want to receive data "numbers" from the micro-controller and display it at the numeric indicator but the buffer of the visa read receives "Strings" only .. any help with this please ??
(3,575 Views)
I have no idea why you would ask this question? You are already correctly using the type cast. Do you think it only works one way?
(3,564 Views)
Typecast can be used for both directions, but it has a middle terminal too. When that is not connected it will generate a string, but when you connect an integer to it it will produce an integer.
Rolf Kalbermatter  My Blog
(3,560 Views)
You also have to remember to set the representation of the constant connected to the middle terminal of the typecast.
LabVIEW 2012
(3,547 Views)
Please go to the help menu and turn on context help. All of the information in these answers is there.
(3,530 Views)
