How can i print using Report VI
hi. i want to print a text to the default printer. in Report Generation i use Report vi but when i run my vi this error apears. "Invalid printer name." where is the problem? thanks. ali mootaab
(2,856 Views)
When you run this code...
Does your printer show up?
Message Edited by jmcbee on 12-02-2008 03:35 PM
(2,853 Views)
Thanks for your attention. My printer is HP and it shows it. Althogh in Report property window I set Destination to 'Print to Printer'. When I set this to 'HTML for Web Page' it creats an HTML file and writes all data in it, but it dosen't work with printer!
Ali Mootab.
(2,832 Views)
