How can i include Polymorphic VIs while building an executable?
am trying include polymorphic Vis while building a stand alone application. It is giving me error. If i use instances of the polymorphic VI instead of using it as library, i am able to build application. is there any way to use the library directly in the process of building stand alone application. Am using LabVIEW 8.0
Anil
(2,916 Views)
What are the errors that you are getting? Polymorphic VIs should have no problem in a built application - it would be a major issue if they did because NI makes extensive use of polymorphic VIs in their driver code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,909 Views)
Hi Mike,
Thanks for ur quick response. I could solve the problem with a simple tick mark (do not include the Vis not used in this master VI).
Now i could build stand alone application.
Anil
LabVIEW 7.0, 7.1, 8.0
(2,902 Views)
