How can i get the raw data from basler camera spl4096 140km??
Hello
I have a basler camera spl4096 140km and I want to get line Intensity profile in real time(raw data), not 0-255 index
How can I get it? Can i get it?
I have VAS not VDM.
Thanks.
(4,138 Views)
It would be helpful to see some code.
I'm assuming you have the correct Camera Link interface hardware in your PC.  I've mostly used USB and GigE (TCP/IP) cameras, which use IMAQdx, so I'm not sure which IMAQ "flavor" you will need.
I don't understand your question -- neither what you want to do, nor the specifications (frame rate, data format, etc.).  What does 0-255 index mean?
(4,096 Views)
Thank you for atteding.
I understand that.. if the intensity of incident light is 100, for example, the camera will accept light and change the intensity (100) to change 2 by taken log function. In this case, 100 is raw data and 2 is data from camera.
0-255 index means By using 8 bit camera, all intensities are changed like the process i told.
I want to use raw intensity data ... how can i use it?
Thanks.
(4,092 Views)
Attach your VI(s) that use this Camera.
BS
(4,089 Views)
How you are acquiring data from camera?
-What is your Video Output Format?
-What is the bit depth of image?
-What is raw data format?
-By default LabVIEW uses 8bit for acquisition, so change acquistion to 16bit using http://digital.ni.com/public.nsf/allkb/A9F3B3352CA802798625780A006DB749
-Know more about 16bit images in LabVIEW: http://digital.ni.com/public.nsf/websearch/3C727E03F004EA528625714900706CA0?OpenDocument
-The 16-bit option can work for any image depth less than or equal to 16 bits.
-Use Bit Shifting to get the 12 bit data from 16bit image: http://digital.ni.com/public.nsf/allkb/3C03FE2B63D1AFC586256C91006F50BF
uday
(4,084 Views)
