How can i generate a report from labview RT
I have vision inspection RT project with Labview RT and EVS , How can i generte a report ??
Message 1 of 10
(3,464 Views)
What kind of Report do you need? A LabVIEW RT Failure log or a Report of your Measurement Results?
Christian
Message 2 of 10
(3,461 Views)
Measurement Results in RT
Message 3 of 10
(3,454 Views)
Then it depends what kind of data it is and how you want to use this report later. Is it necessary to transfer the data to the Host and generate the report there, e.g. using the Report Generation Toolkit.
Or should it be a csv file located at the RT Target so that users can ftp it and analyze it individually?
Christian
Message 4 of 10
(3,447 Views)
OK , I have Basler camera connected to EVS RT with terminal Block and I have done inspection project real time it gives me Pass and different type of Fail
I want to analyze this results in a report in another PC, What can i do?
Message 5 of 10
(3,431 Views)
I would suggest you to use TDMS, which is descriped here. This link also contains examples and a link to download the Excel Plugin for TDMS.
Christian
Message 6 of 10
(3,428 Views)
Can you give me example how to use?
Message 7 of 10
(3,408 Views)
Christian
I just quote myself in case you stoped after the first sentence.
Christian
Message 8 of 10
(3,400 Views)
But i can not transfer the real time data  "TDM"   to the host
Message 9 of 10
(3,387 Views)
Frank,
With this last question, are you just looking for the best way to get the files from the Real-Time Target back to your host computer?
You can use FTP to do this in MAX: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIEiCAO&l=en-US
Best,
Ryan C.
Message 10 of 10
(3,362 Views)
