How can i execute once
i build up small vi to check value from dll file and i want to play sound as it become 0
so as i press Run continuously the sound repeted and dosn't stop until i abort execution
now how can i force labview to play sound once as i in Run continuously mode
i'm waiting u r help
Message 1 of 16
(4,371 Views)
Don't use run continuously...use a 'while loop' with a stop condition...
Search the LabVIEW Help for 'While Loop' for more information.
-B
Message 2 of 16
(4,366 Views)
As noted, don't use Run Continuously. That mode is intended for debugging, not for normal operation. It's equivalent to you pressing the Run button all the time, so your VI starts from the beginning each time.
Message 3 of 16
(4,346 Views)
I would think the name "Run continuously" would be enough of a clue to tell someone who wants to run something only once not to use that button.Smiley Surprised
Message 4 of 16
(4,341 Views)
okay people i think i get your point
but still one question as i build this VI it's gonna to be excute once or continuosly ?????
Message 5 of 16
(4,324 Views)
As noted, a while loop will do that. If you have not already done so, it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
Message 6 of 16
(4,314 Views)
well a while loop will run untill you terminate it or it reaches the conditions you set
if you want to run it once and only once than you don't need a while loop, you could also use a while loop with an event structure
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 7 of 16
(4,297 Views)
You could also do something as trivial as this:
Message 8 of 16
(4,290 Views)
yea this is gonna to work if i run once but continously it will still repet and repet
Message 9 of 16
(4,268 Views)
i can't open your VI i use Labview v8.5
Message 10 of 16
(4,266 Views)
