How can i combine an array of string and an array of integers ?
i have an array of string data [to be used as header], and an array of multiple column integer vakues;i need them together in one file.
Am not able to combine them so that i can write them into a single file.
Message 1 of 19
(8,389 Views)
I am not sure why you are using a 3D array. For your need you can simply build the two 2D arrays, I guess your header is a 1D array.
Message 2 of 19
(8,382 Views)
Accepted by topic author Mahisnair
There are a few ways you can do this.  What I recommend is:
  1. Open the file
  2. Use the Array to Spreadsheet String to turn your headers into a single string
  3. Write this to the file.
  4. Use the Array to Spreadsheet String to turn your numeric data into a single string
  5. Write this to the file.
  6. Close the file
Message 3 of 19
(8,378 Views)
I dnt understand why i get a 3D array at the output of "read from spreadsheet",  again..i am not able to combine the string data and integer data [indicator named " number" ]
Message 4 of 19
(8,377 Views)
i will show you my original vi, i did as u said but the header part is over written by the integer data columns; i only get the integer columns in the text file written.
[Header string is extracted from input file, written to a file and then the integer values[after derieving them from the same input file] is written back into the file where i stored the header strings. ].
VI attached [jan 17 bulid_6]
Thank you.
Message 5 of 19
(8,361 Views)
Attaching the vi as labview 8 compatible also, please help.
Thankyou.
Message 6 of 19
(8,356 Views)
Of course your header is overwritten. You have the Write to Spreadsheet File set to create a new file when it is called.
Message 7 of 19
(8,345 Views)
thanks a lot for the reply, how can modify so than i can get both header and the rest of intger columns [below it] in the same file?
Message 8 of 19
(8,341 Views)
A file is one long string of characters, nothing else. It is up to the program to interpret them in a meaningful way. Same for writing. Simply compose a string with all desired parts and delimiters and write them to a file.
Message 9 of 19
(8,336 Views)
Simply set Append to File to true with a Boolean constant. Having Context Help open at all times is highly recomended.
Message 10 of 19
(8,336 Views)
