How can i close a packed library reference
Hey guys.
I'm trying to open a reference to all the vi's of a packed labrary, I didn't bother to run the vi's after I opened the reference, I just closed the reference, but I noticed that my memory wasn't freed up, I think it might be because I'm not freeing up the packed library, but I can't find out where I can free it up or maybe it's because of something else that prevents me from freeing up the memory.
Run Result
"Main"
"Load VI From Lvlibp"
The Get Memory Usage VI is called "kernel32.dll/GlobalMemoryStatusEx" library to get free memory.
(989 Views)
It depends, how memory manager implemented internally and which value returned from this function.
Try to use VMMap from SysInternals instead to get more accurate and detailed footprint of the memory.
(979 Views)
LV likes to hold on to memory in case it needs it again, don't worry about it.
Qestit Systems
Certified-LabVIEW-Developer
(950 Views)
Function "Get Memory Status.vi" from the Memory Control palette has an output "memory allocated for LabVIEW". In the help, it says: "Returns the amount of physical memory that the LabVIEW process uses. [...]".
I've done a quick test and it seems to give coherent results:
Raphaël
(919 Views)
Thank for your advice.
I will use it to monitor my memory status.
(909 Views)
Thanks for your response.
I would like to prioritize freeing up the original space before my new memory usage, because LabVIEW consistently fills up my application with memory, which I think can be and its something that affects the user experience.
MapleBay
(907 Views)
Thanks,I using "Get Memory Status" to be my memory monitor. But I can't to get the same result.
And when I close my VI or project, LabVIEW still won't free my memory until I close LabVIEW!
MapleBay
(905 Views)
