How can i change a text on the frontpanel?
i have a cluster which looks like the attached cluster but with more and smaller quadrants.
Now i want to add a text above each column. This can be done with a description. But now i want to load the description dynamically from somewhere (file, global) so that it must be changeable. But it seems not to be possible to change the text of a decoration.
What other possibilities are there to add a text above the cluster? I tried to to it with a text-array but there i cant make the text be shown like in the description  (counterclockwise).
Thx for any ideas.
(2,725 Views)
Hi OnlyOne,
you can get acces to them using the property node, but you can´t change the value. You can use boolean controls to do it.
Mike
(2,718 Views)
Hi Mike,
perfect idea. Works great.
Thx
(2,712 Views)
Make the caption visible. You can change the caption text and the vertical arrangement via property nodes.
Lynn
(2,692 Views)
