How can i Access Create_ramp vi directly frm functions pallette
I would like to access some vis in llbs directly from the functions pallette.
if i search for vis in functions pallette i'm not able to find them..
can i add the vis in llbs to Favourites??
please see the attachment
Kudos always welcome for helpful posts 🙂
(3,779 Views)
Accepted by topic author RENN
Hi RENN,
Thanks for the post and I hope your well.
Please look at the following knowledgebase article, it guides you through all the steps:
How Do I Create or Edit a Custom Sub-Palette on the Controls or Functions Palette in LabVIEW 8.0?
http://digital.ni.com/public.nsf/allkb/20AF261D501F8D3786257085005EAE74?OpenDocument
This is the same for LabVIEW 8.6.
Basically, tools>> Advanced >> edit oalette set>>.. brings up window - then you can right-click to browse to a VI to add.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,765 Views)
Warning: You should not directly link to a VI that's in the examples directory. You should copy the VI and place it into your project's directory structure. Future versions of LabVIEW may not have those same examples, or they may be different, which means your code may stop working.
(3,755 Views)
thanks very much for your valuable suggestions!!Smiley Happy
(3,659 Views)
