How can do 8-to-16 bit modulation in Labview
Dear All,
I would like to make 8-to-16 bit modulation (as like DVD do known as EFMPLus encoding) using Labview.
What I want to do is: Firstly I can convert any image file into decimal format/binary file. Than decimal / binary format file save to the spreadsheet file. I want to apply 8-to-16 bit modulation techniques on the spreadsheet file.
Please advice me if there any way to make 8-to-16 bit modulation in Labview.
Many Thanks, Azim
(2,325 Views)
http://en.wikipedia.org/wiki/Eight-to-fourteen_modulation
You have to implement this yourself in code.  There is no VI that can accomplish this all on its own.
First you will need to take your data and break it up into 8-bit chunks, using the split number VIs, and then build your 14 (not 16) bit values according to the rules set forth in EFM
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,295 Views)
