How can a LabView process communicate with a Visual c++ process
How can a single Labview process communicate with another Visual c++ Process?
Both Application are running separately. The LabView  Application must have the Possibility to send command to the C++ Application and receive Data from this process.
Thanks.
(4,347 Views)
You can ask the same exact question another way: How can I get one Visual C++ process to communicate with another Visual C++ process that's running separately? The same situation, so the same answers would generally apply.
Is this an application that has already been written? Does it have an ActiveX interface? That's probably a good way to go since you can control the application directly from LabVIEW. Another method is to use TCP/IP to talk back and forth. Another method is to use the SendMessage API function. Does it have to be an application? Can it be a DLL? For a DLL you could have a function that's called by LabVIEW that starts the main process and then functions for sending/receiving data. This thread mentions using datasockets. I'm sure somebody else can suggest other methods.
(4,343 Views)
"Marcel1" <x@no.email> wrote in message
news:1145544009067-354474@exchange.ni.com...
Process?
> Both Application are running separately. The LabView &nbsp;Application
> &nbsp;
> Thanks.
I have heard active-x but that's all I know.
Tam
(4,317 Views)
Thank y for your answer.
The c++ application has already been written but don´t have an external interface.
The LabView application can have an activeX  interface other dlls.
Do you have some LabView example code using activeX interface other another Method to communicate with a c++ application?
I have no practical experience with the interprocess communication.
Any example in LabView will help me.
(4,293 Views)
Which development environment are you using? If you are using MS Visual Studio 2003 .NET or newer, I suggest you use .NET interface. If you are using MS Visual Studio 6.0 I suggest you use ActiveX interface. .NET interfaceing is quite easy, you only need to create your interface library in managed C++ and you can directly call it from Labview. You can even register you .NET events so that they can trigger events in Labview. See managed extension to C++ in google. You can create programs so that you mix both conventional C++ and managed C++. This fourm however is not appropriate place to talk about managed C++ in detail.
Tomi
Tomi Maila
(4,283 Views)
Hello Tomi,
I am using MS Visual Studio 6.0.
Where can I find a functional LabView example using activeX interface to communicate
with a Visual Studio 6.0 application?
(4,272 Views)
