How can I wire a string value to the case selector terminal and depending on that value, execute a selected case?
Hi Everyone
In the block diagram of the posted VI, thru serial comm, byte #2 is either 00 or 01 (Hex). This byte should dictate which case to execute. If Hex value = 00 executes case #1, If Hex value = 01 executes case #2. If neither, nothing should execute.
How can I do this? I am fairly new to LabVIEW any feedback is highly appreciated.
Mahir
(4,902 Views)
Accepted by topic author mhaque
easier to just wire in the integer to the case structure rather than convert to string.
Then just go up to the case selector and type what you want.
Paul
(4,894 Views)
Also note that you can change the radix on the case structure so that the case selector will look like a hex value.
(4,883 Views)
sweeeeeeeeeeeeeeeeeeeeeeeeeeeet!
Smiley Very Happy
(4,868 Views)
