How can I use the TLB Library ( Disto A6) on my application?
How can I use the TLB ( typed library ) in vi???? Can anyone teach me how to use? Thank you.
(5,270 Views)
I am pretty sure you will have to embed the type library with a DLL, and then call it from LabVIEW using the Call Library Function Node. However, I will verify if we have any other way of calling a type library from within LabVIEW.
Vivek Nath
Machine Vision
(5,254 Views)
How exactly was this type library created? In what programming environment was it developed?
Vivek Nath
Machine Vision
(5,241 Views)
Here is the typed library. It contain two class : application and measurement. However, when I use the measurement library, the error message always pop up.
(5,232 Views)
You cannot directly use a type library file in LabVIEW. You need a COM object, like an ActiveX control. Do you have one installed for this "Disto A6", whatever that is? You said "when I use the measurement library, the error message always pop up".  How are you using it? What error message?
(5,218 Views)
Leica Disto A6
A type library is the description of the interface a COM object like an ActiveX control or ActiveX automation server has. LabVIEW is using the information in a type library when you use the"Select ActiveX class" dialog. You must have the ActiveX control or automation server installed to use it in LabVIEW and on your target machine when running a built application.
I think he tries to use DISTO™ transfer to get the measurements.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(5,199 Views)
