How can I use the Control Design & Simulation module in the Mobile (PDA) modul?
Hi everyone!
I have to create Bode and Nyquist plot from Transfer function on a PDA, but I can't use CD&S Modul when I'm opening a new Mobile project.
Thank you for your answer!
Sincerely yours,
Jenő Kocsis
Message 1 of 17
(4,526 Views)
Jenő Kocsis wrote:
Hi everyone!
Sincerely yours,
Jenő Kocsis
Does it have to any transfer function? Or is it some limitations
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 17
(4,522 Views)
This is a limitation.
I have to do something like the Attachment on a PDA.
Message 3 of 17
(4,518 Views)
Replace s with jx2xpixfreqency. Then use complex math functions in Labview. Vary the frequency and calculate enough points to draw the plots. Then use the Complex To Polar Function for drawing the bode plot. The r is the magnitude and theta is the phase. theta is in radians! Plot this values against the frequency. I am not sure for the Smith plot. But it is something in the same alley
Message 4 of 17
(4,507 Views)
I'm trying it, hope it'll work.
Thank you!
Message 5 of 17
(4,495 Views)
Hi I have some questions regarding eq3 and eq4. Which one is the feedback loop, and is it positive or negative feedback? Since you have a feedback loop you must take this into account.
Message 6 of 17
(4,491 Views)
That file was just an example.
Btw eq3 and eq4 are in a parallel connection so not a feedback, there is a little + sign.
 I've made this bode plotter, please, can you check it?
Message 7 of 17
(4,488 Views)
I've made the VI, but there is an error. The cut-off point is'nt there, where is should be.
There is a 10e-1 dislocation.
Message 8 of 17
(4,468 Views)
Please post your equation;)
Message 9 of 17
(4,464 Views)
Which equation? My equation is in the attached vi.
Message 10 of 17
(4,454 Views)
