How can I use multiple display on CompactRio?
Hello everybody,
I am working in a project where I have connected two displays on CompactRio. I can see the program in two screens at the same time but I would like to have a VI in a screen and another VI in another screen.  I am using a DisplayPort to splitter two VIs in two screen.
The Display port  to Display Port Multimonitor Sppliter is the next link:
https://www.startech.com/uk/AV/Displayport-Converters/mini-displayport-mst-hub~MSTMDP122DP
The CompactRio what I am using is cRIo 9035.
Any suggestions will be very helpful.
Thank you so much.
A regard
Pedro
(3,607 Views)
I presume you want to have the VIs be displayed on different monitors at run time.  Have you tried setting the Window Run-Time Position properties of these VIs?  There is a Monitor setting (Property) that (on my system with two monitors) can take on the values Primary, 1, or 2.
(3,593 Views)
Is it possible to have two monitors on the mini display port of a compact rio? You can normally identify the monitors from the display menu in linux.
(3,581 Views)
