How can I use backslash code in search/split to split on ascii code 160 nbsp
This seems like it should have been asked already but, I am not seeing it. I would like to split a string at the nbsp code ascii 160.
(3,329 Views)
Accepted by topic author Steve_Steiner
If you right-click a string constant (or indicator or control), you can select Hex Display. The hex value for 160 is "A0", so you can type that in and you should be able to find that character now.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,323 Views)
nk you so much! I figured it was simple but...those are usually the hardest to find...thanks again!
(3,311 Views)
