How can I use a counter input to trigger a waveform
I want to read the counter input from a PCI-6711 card and trigger generation of a waveform at every rising edge of the counter. How can I do that? Please help
(2,811 Views)
VarunKumar,
I believe we will need a bit more information regarding your application:
1. Are you looking to generate Analog Output using simply and External Clock? (i.e. Generate samples every Rising/Falling Edge)
2. Are you looking for a re-triggerable Analog output system generating arbitrary waveforms on a pulse trigger signal?
3. What have you tried so far in implementing this system? Are there any VIs in the LabVIEW Example Finder (Help>>Find Examples), that may implement such techniques?
I appreciate your time working through this issue, please post any more detailed information regarding the trouble you are having implementing the generation system.
Cheers,
Patrick Corcoran
Application Engineering Specialist | Control
(2,793 Views)
