How can I transmit to a subvi a cluster containing elements in a listbox
I have a cluster containing listboxes. when i transmit the cluster in a subvi I loose the elements in the listboxes (thats logic because a listbox return a number). Is it possible to use the properties of the refnum in order to recover the elements in the listboxes
thanks
(3,036 Views)
To me you've got 2 choices :
1) Use the property node "Element names" of your listboxes and transmit them into your subVI if you only need that property in your subVI.
2) Use references of your listboxes and transmit them into your subvi. This method enables you to access to all the properties and methods of the listboxes.
Hope this helps !
Julien
(3,036 Views)
hi,
yes we can do like this. but i have a lot of listboxes in my cluster so i m going to transmits all the reference of each listboxe.
is it possible to recover the element names of each listboxes from the refnum of the cluster
thanks
(3,036 Views)
Here's how to recover the element names from the refnum of the cluster itself.
Hope this helps !
Julien
(3,036 Views)
hi julien,
I can't open your vi because i have labview 6.1
(3,036 Views)
VIs available for LV6.1
Hope this helps !
Julien
(3,036 Views)
