How can I split a signal coming in from an instrument?
I have a device (USB-TC made by Measurment Computing Corporation) that reads in 3 thermocouples in real-time and sends the information to my computer via USB. I am getting one signal from the instrument, how can i split it up into each thermocouple's information in LabVIEW 7.1?
Cory K
(2,538 Views)
You are going to have to clarify what you mean by 'one signal'. If you can specify a multi-channel acquitisiton, then you should be getting back at least an array where each element in the array represents a channel. If you are specifying a single channel and getting back a scalar, you would need to call that three times with a different channel each time.
(2,534 Views)
