How can I show/hide the windows cursor in a LabView 7.0 application run under Windows XP?
VI used In Win2000 does npt work in XP
(3,524 Views)
How are you doing it in Windows 2000? Are you making a system call to shut off the cursors?
There is a palette of cursor manipulation (Application Control -> Cursor or just do a palette search for "Cursor"). These VIs let you set the cursors, but I don't see an easy way to turn it off. A work-around might be to have a blank cursor in a cursor file and change the cursor to that. It will still have a click response (hot spot), so it does not keep the user from using the cursor, just seeing it.
(3,524 Views)
Take look at this example:
Confining Mouse Cursor to Front Panel of VI
This does not hides the cursor, however you can limit it's movement to the bottom corner of the screen and the user won't be able to use the mouse at all.
I hope this helps.
Juan Carlos
N.I.
(3,524 Views)
Use G Toolbox / Show Cursor.vi, you can show or hide a window cursor.
http://gtoolbox.yeah.net
George Zou
(3,524 Views)
