How can I set an overlap for PID control on 2 outputs
I found a similar topic how to set a deadband for PID control. Understood the solution, but now I wonder how can I set an overlap band for PID control, with overlap band in process unit (not PID percentage). Is this not possible with one PID block ?
Thank you!
(2,771 Views)
Hi Zigbee1,
I could not find an existing example that already does this. Based on what you’ve described, I think the Dual Channel PID example would be a good starting point to implement this.
The PID VIs themselves aren’t password-protected, so you could potentially modify them to suit your needs.
Have you taken a look at that example?
Kyle S.
http://www.ni.com/support
(2,698 Views)
