How can I set a Boolean LED the moment a trigger occurs on PFI-0
I want to turn on a front panel LED soon as I get a trigger.
Please see attachment.
(3,011 Views)
Accepted by topic author dhardy41
probably use an event structure :
Monitor the PFI-0 line and as soon as a change happens, the event structure should kick in and tuen the LED or do whatever you want to do on the front panel.
Cant open your file because Im using a later version that yours.
LABMAT
(3,004 Views)
Thanks LABMAT, that worked out great!
(2,958 Views)
If you really wanted to thank him you would give him kudos and/or accept his post as the answer to the topic.
(2,948 Views)
Thnx 4 my 1st kudo 🙂 glad I cd be of help.
Labmat.
(2,922 Views)
