How can I send binary data (not ASCII) through a UDP packet?
I would like to send hexadecimal data string (e.g. 0x12AB) directly through a UDP packet.  I send the hex string to the UDP write and it gets translated into ASCII (e.g. 0x12AB = 31 32 41 42) before it is sent.
Is there a way to get the UDP write to skip the ASCII translation?
(4,604 Views)
No it doesn't. A string is a string. Check the display format of the various string indicators. Maybe you are doing something wrong. How do you generate the "hexadecimal data string? (Right= "typecast", wrong= "number to hexadecimal string")
If you are still confused, please attach a simplified example of your VI.
(4,595 Views)
Much Appreciated.
(4,586 Views)
