How can I see a run time error?
When I run the VI in development mode the VI works just fine. But after I compile and run the VI I get an error that flashes across the screen and then disappears. Arggg! How can I stop the process to see my error?
(2,948 Views)
Steve,
There are a few possible solutions to this.
One, I am writing an article about right now. It involves writing a Loader. This is a simple VI that loads and runs your main program, so that it can remain as a VI. If this is a viable solution for you (your VIs remain as VIs), then it is probably a great solution, as you won't have to worry about why your VI runs differently as an executable than in development.
The second is a lot more involved. You need to troubleshoot this error. First, you should already have in place some good error handling. If you don't, get it. Once you have it, or if you already do, you need to determine about where the error is coming from, and start putting in some troubleshooting. I always like to create a singl
e Global Variable (this to me is the ONLY good use for a global) with all sorts of indicators to act as a runtime probe (since you can't probe a built application.) You just write values to various controls as you need them, when you need them, and this allows you to view those values. Since this is designed primarily to view data in reentrant VIs, you will have to create a viewer for your built application. Simply create a VI that loads when you run your app that displays all of the global values.
Those are the only suggestions I can offer for now. Without knowing the nature of the error, etc, I can't give you any further advice.
(2,947 Views)
The OpenG Application Builder has a feature that allows you to open any VI in the LabVIEW run-time engine. You can do this from the pull-down menu, or by right-clicking on the VI from Windows Explorer and choosing Open in Run-Time.
OpenG Application Builder: http://ogab.sourceforge.net
Version 1.0 was just released with this new feature.
(2,947 Views)
Try the following (it works under Windows, I don't know about the other platforms): right click on your suspect VI, and choose "Open With...", then open it with the built executible (you will need to browse to find it) - if there's an error, it will now be displayed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(2,947 Views)
