How can I reset my VI to default values when I stop it ?
I have a VI with changing values when I click on start the value start with the defauts values, but when I stop my VI and I want to restart it the values are the last values in memories before I stop the VI, to solve it's problem I close my VI and I open again the program... it's not fun...
I would know if it exist a method to do this automatically, like if I click on the edit menu on "put in defauts values"...
Bye.
(12,515 Views)
Accepted by topic author leo2b
Hi leo2b,
you can use the "Resettodefault" method at the end of your vi.
See the attached example.
Mike
(12,511 Views)
Mike's suggestion is best.
If the 'start value' needs to change, you could use local variables to set the initial values.  But, this is not the preferred method.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(12,509 Views)
One way is Edit -> Renitialise values to default
Keyboard shortcut in 8.2 is Alt E Z
It can also be done programmatically;
From the Application Control pane, drop "Vi server reference" - it will show as This Vi,
Drop an invoke node from the same pane, and wire the server reference to the reference input, and set the method to Default values . reinitialise all to default.
Rod.
(12,505 Views)
Thank you for your responses I will try your methods.
bye
Message Edité par leo2b le 07-24-2009 09:21 AM
(12,492 Views)
