My goal is to provide context sensitive help for each control displayed on the front panel using a help file created externally. I know that at the VI level I can specify a Help Path; I want the same behaviour for each control inside a VI. I also know about creating a custom control and specifying the Help Path in there, but it doesn't help in this situation, for I have hundreds of controls in my application and I cannot go back and replace each one with a unique .ctl. If I could override each instance of the custom control with unique path data that would do the trick, but that's not how it works.
Is there a way to add the Help Path information to regualr controls?
-euge
ne
