How can I reduce the propagation delay of a 32-case structure??
Basically, I have this one case structure in my single cycle timed loop on a 40 MHz FPGA target and this one structure keeps causing the theoretical maximum clock frequency to be less than the desired clock frequency.  If I use a disable diagram structure around this thing, the code runs, so I know it's this specific part of the VI.  I guess my question deals with how I can reduce "combinatorial paths" and propagation delays in this case structure.  Could I replace the case structure with something else, achieve the same results, and fit everything in an SCTL effectively??  I know seeing the files will help big time, so I'll upload them ASAP.  In the mean time, any tips and tricks are greatly appreciated.  Thanks!
(2,806 Views)
There a few tutorials for optimization of FPGA code.You can reduce the combinationsal paths by using pipelining and parallelism.
Optimizing your LabVIEW FPGA VIs: Parallel Execution and Pipelining
(2,756 Views)
