How can I realize the function of the CAN communication between USB-8502 and USB-8473
Hi,all
I have two can cards, one is usb-8502, another is usb-8473.
Now I want to realize the can communication between these two cards. And the 8502 is a XNET card, 8473 is a common can card.
For the electrical connection part, I don`t know if i only need to connect CAN_HIGH to CAN_HIGH and CAN_LOW to CAN_LOW, Do i need to switch them(CAN_HIGH to CAN_LOW)? Besides, Do  I need two 120Ω resistance  to connect  both side?
For the software part, Is there any limitation between the different can communication ways as the 8502 use the XNET and the 8473 use the CAN?
As you know, I am quit new to the CAN communication. I hope you can help me.
Thank you in advance!
(2,231 Views)
Accepted by topic author open28
Hi open,
This is explained in the manuals of both modules. And in almost all documentation on CAN bus…
(You connect CAN-H to CAN-H and CAN-L to CAN-L. Usage of termination resistors as documented!)
CAN communication always is the same. The only difference between both modules is the driver you need to use…
(2,228 Views)
