How can I read a comment from an lvm?
I created an lvm using the Write to Measurement File express vi and I added a comment.
To simplify it the line of the lvm created was:
5 test
where 5 is a random value and test the comment I input.
My question is how can I read this comment.
When I use the Read Measurement File express vi, the comment output
returns empty.
Thank you.
(3,129 Views)
Hi epik78,
I am not sure how you are adding your comment to the file, but when I made the simple VI below, I was able to see the comment that I input to the .lvm file in the comment indicator of the Read From Measurement File.
Stephen S.
Message Edited by Stephen_S. on 02-25-2009 03:18 PM
Applications Engineering
(3,099 Views)
Thank you for your reply.
I tried your way but still nothing.
Ive attached a vi that does not do it for me.
Can you check it?
Thank you.
(3,095 Views)
Accepted by topic author epik78
Hey epik78
When I ran your code I got the same performance your described. Try selecting either "One header only" or "One header per segment" under the Segment Headers section of the Configure Write to Measurement File window and you should be able to retrieve that comment when you read from that file.
Hope this helps.
-Ben
Hope this helps.
-Ben
WaterlooLabs
(3,076 Views)
You are right,it works if you include a header.
Too bad I cant have the files I want to create with a header.
Thanks for the help.
(3,074 Views)
