01-26-2009 11:34 AM
Greetings, I am developing a LabVIEW application for a PDA (HP iPAQ in this case), and a companion VI that will run on a PC. One of the things I need to do from this companion VI is provide a means of programmatically rebuilding the PDA application, including reinstalling support for DAQmx Base. I think I know how to rebuild the LabVIEW application using the Project, but I don't see how to install DAQmx Base. What is the best way to do this?
Thanks in advance!
01-27-2009 04:02 AM
01-27-2009 10:46 AM
The point is to do this programmatically, not from right-click menus, so I'll need to go with your second solution. I see there are three EXEs in that folder: DAQmxBaseCEsetup.exe, DAQmxBaseCEsetup_tpc2006.exe, and DAQmxBaseCEsetup_tpc2012.exe. Do I run the first one?
Also, it turns out that I can't build the LabVIEW executable programmatically (the Project API is not available in LabVIEW Run-Time). Do you know how to programmatically transfer data files from the PC to the PDA?
Thanks!
01-27-2009 10:24 PM
Yes, you would run the first executable.
You could try using FTP to transfer the LabVIEW executables. NI has FTP VIs in it's Internet Toolkit; you will have to google if you want to find something for free.
01-29-2009 10:16 AM
