How can I programatically modify a teststand sequence global in Labview ?
I am automating some tasks using Labiew to modify data in a Teststand sequence file. How can I programatically modify the value of a Sequence Global from labview ?
Sam
(3,877 Views)
This should do it:
Note the method name will have to change based on the type of global you want to modify.
24148iC681608BBF847030
Eric S.
AE Specialist | Global Support
(3,852 Views)
How would I be able to get a sequence context that references the sequence file that I am trying to edit. I tried converting the sequence file ref to sequence context but that didn't work.
Sam
(3,820 Views)
You have to pass in the TestStand variable RunState.ThisContext to the vi through the connector pane.  I'm not sure about the exact variable name because I don't have TestStand loaded at this time.  But  there is a variable for the sequence context in TestStand and this has to be passed to the vi.  Note that you cannot run the vi stand alone.  You must run it from TestStand in order to get the proper sequence context.
- tbob
Inventor of the WORM Global
(3,813 Views)
This will not work because I am using only Labview. I run my VI as a standalone VI.
Sam
(3,796 Views)
You cannot get a sequence context where none exists.  Without running TestStand, there is no sequence context.  What you are wanting to do is impossible.
- tbob
(3,778 Views)
