How can I plott data from a text file in the same way as a media player using the pointer slide to go back and fort in my file?
I would like to plott data from a text file in the same way as a media player does from a video file. I’m not sure how to create the pointer slide function. The vi could look something like the attached jpg.
Please, can some one help me?
Martin
(2,571 Views)
HI Martin,
i am not realy sure what you want!?!?
i think you want to display only a part of the values you read from XYZ
so what you can do:
write all the values in an array.
the size of the array is the max. value of the slide bar
now you can select a part of the array (e.g. values from 100 to 200) and display this with a graph
the other option is to use the history function of the graphes
regards
timo
(2,566 Views)
Hi Timo.
I will try your suggestion.
Many tanks!
Martin
(2,562 Views)
