How can I plot multiple curves automatically ?
How can I plot multiple curves automatically using the XY graph,
for example to load an array of a file each time and plot it with the old curve ?
THANK YOU .
Message 1 of 10
(4,299 Views)
Hi Sarah,
create an array of plots:
Message 2 of 10
(4,296 Views)
HI KNIGHT OF NI.
in your example you put two plots what I want is to add them automatically Possible up to 100 or 1000.
I do not know how to create an dynamic array and load it dynamically or load it  automatically add the data in this array.
Message 3 of 10
(4,287 Views)
You need to build the array of plots in a shift register.
(I would not recommend 1000 plots on a single XY graph. How many points per plot do you have on average?)
Message 4 of 10
(4,283 Views)
In fact the idea is that I made a program that loads information in csv. this information in the form of a array of data.
Then the user when it loads the first it appears without problem but the problem that when I get the second array I want to plot it with the old etc ...
Then I dont know the limit exactly and for not to abuse it can take 50 curves maximum.
But how i can do that dynamically  .?
I hope you understand.
Message 5 of 10
(4,273 Views)
I already told you that you need to build the array of plots in a shift register whenever a new plot is added. Are you familiar with that?
Message 6 of 10
(4,264 Views)
You mean that I must to create many arrays and build them with a shift ? No i dont know how i can do that .
Message 7 of 10
(4,255 Views)
No, just one array of plots. (XY graphs take a variety of datatypes. How is the data arranged in the file, how are you reading the single plots? Seeing your VI would help).
At this point, you should continue with a few more LabVIEW tutorials.
Message 8 of 10
(4,244 Views)
I searsh a method to store this data with each Double click in the array 2D  for example and display them on the graph.2.png
Message 9 of 10
(4,232 Views)
These are just pictures. All we see is "rube goldberg type code", unrecognized subVIs, and blatant overuse of local variables. If you want help, attach actual code.
You data is always equally spaced, so all you need is a waveform graph. No xy graph is needed, simplifying the data structures significantly.
Message 10 of 10
(4,227 Views)
