How can I paste a string into a search field of an html-site and subsequently activate the "search-button" of the site?
my problem is the following:
I would like labview to paste a string (e.g. 123xyz) into the search field of an internet site. Subsequently labview should activate the search by clicking on the "search-button" or activating the "search-link" of this site.
My question is:
Which elements of labview do I have to use to create such an application? Do I have to use DataSocket-functions? Are there example-vi's existing and if yes, where can I get them from?
I'm working now since a couple of days on this problem but I still have no good results or ideas, perhaps because I'm an novice.
Thanks alot for your help,
um
(3,022 Views)
If the search button just updates the url then you can use datasocket like this.
In labview 8.2 you will find the datasocket vi's in Data Communications -> Datasocket palette.
hope this helps
David
Message Edited by David Crawford on 02-01-2007 02:26 PM
(3,012 Views)
Thanks David! I tried your example and it worked very well. But I think I have to explain my question in a little bit more detail: In context with protein analysis I have to paste aminoacid sequences into a search field. Then I have to activate the search button and get some information about the protein. This information do I have to extract then. Up to now I do this all manually by using my computer mouse. You have to know that I want to analyse more than 500 proteins in the next weeks. I’m sure you can imagine how much copy-and-paste-work this is. So my hope is to create a tool doing all this work automatically for me. The adress of the site is http://www.expasy.org/tools/protparam.html. There you can see a big box where I can paste my aminoacid sequence (e.g. MSQDGKVKTTESTPPAPTKARKWLPVLDPSGDYYYWWLNTMVFPIMYNLIIVVCRACFPDLQHSYLVAWFVLDYTSDLLYLLDIGVRFHTGFLEQGILVVDKGMIASRYVRTWSFLLDLASLVPTDAAYVQLGPHIPTLRLNRFLRVPRLFEAFDRTETRTAYPNAFRIAKLMLYIFVVIHWNSCLYFALSRYLGFGRDAWVYPDPAQPGFERLRRQYLYSFYFSTLILTTVGDTPLPDREEEYLFMVGDFLLAVMGFATIMGSMSSVIYNMNTADAAFYPDHALVKKYMKLQHVNKRLERRVIDWYQHLQINKKMTNEVAILQHLPERLRAEVAVSVHLSTLSRVQIFQNCEASLLEELVLKLQPQTYSPGEYVCRKGDIGREMYIIREGQLAVVADDGVTQYAVLGAGLYFGEISIINIKGNMSGNRRTANIKSLGYSDLFCLSKEDLREVLSEYPQAQAVMEEKGREILLKMNKLDVNAEAAEIALQEATESRLKGLDQQLDDLQTKFARLLAELESSALKIAYRIERLEWQTREWPMPEDMGEADDEAEPGEGTSKDGEGKAGQAGPSGIE) in. Then you have to press the “compute parameter”-button and extract the interesting data from the resulting site.
Is it difficult to realize this? Do I need CGI knowledge or does there exist a special labview-vi? Perhaps you can help me again.
Thanks alot!
Best wishes,
Ulrich
(2,983 Views)
Sorry I don't know how to do that.
I tried looking at the html of that webpage to guess what to next but its really not my thing. My example is just something I had seen before and wanted to offer it as a possible solution.
Good luck!
David
(2,980 Views)
