How can I move data from one loop to another?
I am using LabVIEW to record and display data.  The problem that I have run into is that if I try to collect and display the data all in one loop data points are lost because the loop takes so long to execute.  I decided to break my program into two independent loops and the data is recorded at proper speeds, but now I cannot get the data out of the first loop and into the second loop.
(3,050 Views)
Use a Queue
Look up LabVIEW Producer Consumer example.
Omar
(3,048 Views)
See my example for one method of how to setup the Queue which Omar suggested. You'll also see many other ways, most of which should be avoided until you get more experience.
Communicating Between Loops
Richard
(3,029 Views)
