How can I make this in labview : find the numbers of overlapping between bits
Altenbach, I agree. I just know on certain RT systems (*cough cough* cRIO) I have had to switch from boolean to bitwise comparissons because the number to boolean array was hurting my timing. So, I just wanted to throw this possible solution out there in case that is a requirement for anyone. On a PC or beefy PXI controller, the readability of the boolean array plays the trump card on the bit twiddling without a doubt. But, I have seen it negatively effect performance in certain cases.
Message 11 of 14
(512 Views)
Greg, Now i am thinking why number to boolean array causes problem some time on dedicated system.
Is that because you already have bits ( some value ) stored in memory and now you are building an array so basically adding a 32 bit header and following same bits again so conversion does not play any importance in terms of calculation ( actually adds overhead ) because however we interpret it computer or hardware will see only 0 and 1.
Right, wrong or absolutally wrong
Message 12 of 14
(505 Views)
Someone can probably give a better answer than I, but I assume it has to do with the fact that in memory a U32 takes up 4 bytes (i.e. 32 bits), but because each boolean in LabVIEW takes up a byte, not a bit, there is some additional overhead converting from one to another. So, a 32 bit number, when converted to a boolean array now becomes 32 bytes. I don't know what the overhead associated with this is, or when it no longer becomes negligible (i guess that is application specific), but I'm just commenting on what I've seen.
Message 13 of 14
(494 Views)
A boolean array is very wasteful because only one of every eight bits carries any useful information. The rest just wastes memory.
Message 14 of 14
(492 Views)
