How can I make the points visible in Graph
HI,
I have a graph which plots certain points. I want the graph to also make the points visible - not just the lines between the points.
How can I do that
(2,677 Views)
Right mouse on the graph and select common plots. Under there you can select how you want to display your information. After selecting the display with points, you can go further down the list to Point Style to choose circles,squares etc....
(2,677 Views)
