How can I make a for-loop loop increasingly?
I want a for-loop within another for-loop to loop x, x+1, x+2, x+3...etc. times within this other loop. Does anyone know how I can do this? Thanks
(2,988 Views)
Is something like this what you're trying do?
(2,988 Views)
you just need to add "X" to iteration number of outer loop "I" and wire the result to the number of iterations of the inner loop "N".
Look on the diagram of attached example.
Good luck.
Oleg Chutko.
(2,988 Views)
Wire up the "N" terminal of the inner loop to "i" + X.
In other words, inside the outer loop, add the "i" terminal to your constant X, and use that as "N" of the inner loop.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,988 Views)
